Hi,
several months ago I saw a picture on the web,
but now I cannot find it again,
and no copy or bookmark ...
The picture showed a (metal?) base for mannequins;
but instead of the usual short support rod,
it had a rather long support rod,
intened to support the mannequin between her/its buttocks.
This base/rod-combination was advertised "for skirt displays";
on the same page was also a base/rod "for trousers displays",
where the rod was even higher and with some device to clip the rod to the waistbelt ...
The advertisement praised this 2 base/rod-combinations as useful,
when the mannequins disply shoes: the shoes need not to be demaged with a hole for the "usual" rod ...
The rod was not a straight pole (as usual for dressmakers forms), but was bent;
with a butt plug mounted on the top of the rod,
the plug would meet its "natural socket" of a (living) mannequin!
I wanted the picture as inspiration (and maybe later illustration) for a mannequin story,
but - as told - I cannot find it again;
probably I must get inspiration just from memory ...
I'm not sure whether the site was english or german,
but google helped neither language nor the other ...
Anybody found something similar?
window dressee
PS: at the dollification forum there is a picture of a dolly stand;
this remembered me and lead to this question,
as the mannequin base is closer to my wishes than this specific dolly stand
base with rod up to the buttocks
- 50+ FIMS Regular
- 50+ FIMS Regular
Re: base with rod up to the buttocks
Hi,
not the link I initially asked for, but similar inspiring:
http://www.lustundliebe.de/lustundliebe ... ttel_e.htm
and then click in the right upper field on "saddle" or "base plate" (or "metal bars")
window dressee
window dressee
