We all know Youtube Storyboards , Its the images of the video generated when you hover on the seekbar of the video , its great but it gets tiresome keeping hovering on the whole video scanning it for scenes , but with this following method , it isn't tiresome anymore
There is a way to easily download those Storyboards , and in a High quality , and view them in a single HTML file and all you have to do is to scroll down and happy hunting
The Method is to use a program called yt-dlp , You can download it from here , download it in an easy to access directory ( for example , downloading it in a folder called yt that its directory is C:\yt ) , then Run CMD , then inside CMD browse to the folder containing the yt-dlp.exe , in our example its C:\yt , after accessing the folder , Copy and paste the following command
Code: Select all
yt-dlp -f sb0Code: Select all
yt-dlp -f sb0 https://www.youtube.com/watch?v=tR8E-VMKU0sKeep in Mind , The Images displayed in the file is limited to how youtube generate those images in the seekbar , so in short videos the gap between a pic and the other could be one second , in long videos the gap could be up to 10 seconds , so there is a space for error the longer the video is , so for longer videos if there is no clear ASFR moment visible but there is signs for it so its worth checking the video itself
Example of a Short video ( Perfect for Commercials )
Code: Select all
Example of a Long video
Code: Select all
yt-dlp -f sb0 https://www.youtube.com/watch?feature=shared&v=XdXmfW8DNgM
