Tek Streams!
MCtek
400+
Tek Streams!
Post by MCtek »
Hey gang,
Starting the stream in a few mins, hope to see you all there!
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Daniel~
picarto.tv/Tek
First time commissioners get a 2 character sketch for $20!
No need to buy to come join the stream!
Re: Tek Streams!
Just wanted to post-
I never thought I???d have the patience to sit through a live stream before, but after writing for five straight hour???s yesterday evening, I decided to take a much-needed break. I dropped-in on Tekka's session last night, and now I think I might be hooked! It???s really cool to witness the creation process from scratch. There were a couple ASFR-related commissions, including a carbonite transformation, a deactivated / recharging French maid, and even some sexily posed furniture pieces. If you have nothing to do some night, stop by & check it out. Doesn???t cost anything to join Picarto to sit there & watch; you just need to create a user ID (most likely due to the nudity) and to be able to leave comments / suggestions. If you're familiar with his poser work, then you'll love his hand generated stuff. As Tekka mentioned above; first time commissioners get a 2 character sketch for $20. You're only limit is your imagination, and Daniel will take care of the rest???
monkeyjr
Re: Tek Streams!
Post by monkeyjr »
Posting to also highly endorse Tek, glad to finally join his streams, he's one hell of a talented dude!
MCtek
400+
Re: Tek Streams!
Post by MCtek »
:D thanks guys, glad you guys had fun, for those wondering, while commission will be avaible during the stream it's not necessarily a have to purchase to come and enjoy the stream, think of it as a interactive chat room with statues and timestop stuff here and there being drawn, i do other fetish stuff but those are usually case by case. If you all have time come on in have fun and talk to other like minded people :D the more the merrier!
Daniel~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Whelp, i offically gone thru my what, 3rd vid card in about a few months....=.= it's working atm but i can't do anything huge, like render, or draw, or even play games. I have no idea what's causing the problem, it just does it when i do something, I was in the middle of working on a poser commission when the monitor went blank, the video card's fan when insanely loud and stuff froze. If you have any idea what could be causing it let me know! i can use the help while i try to locate a spare vid card to work from in the meantime. I don't have the funds to go out and by a new one that's better. Here's my specs if you think it may be something else.
Tek~
Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
NVIDIA GeForce GTX 680
512 MB SSD
1.5 TB HDD
16 GIG of RAM
ASUS MAXIMUS VII HERO ATX motherbroad
Lord Hypno
Hypnotist
Re: Tek Streams!
Post by Lord Hypno »
MCtek wrote:Whelp, i offically gone thru my what, 3rd vid card in about a few months....=.= it's working atm but i can't do anything huge, like render, or draw, or even play games. I have no idea what's causing the problem, it just does it when i do something, I was in the middle of working on a poser commission when the monitor went blank, the video card's fan when insanely loud and stuff froze. If you have any idea what could be causing it let me know! i can use the help while i try to locate a spare vid card to work from in the meantime. I don't have the funds to go out and by a new one that's better. Here's my specs if you think it may be something else.
Tek~
512 MB SSD
1.5 TB HDD
16 GIG of RAM
there could be a few problems first I would look at your power supply it may require you taking it apart if it's older and out of warranty I would suggest that look for bad capacitors if you know what they are a quick Google search of what a capacitor is if you don't if you do have bad capacitors you could be getting intermittent voltages to the video card which may be causing it to fail the second thing would be again maybe your motherboard make sure there are no bad capacitors on there
In my years of repairing PCS I've seen quite a few bad capacitors cause some crazy problems the only other thing I could suggest is getting a UPS or some other type of power conditioner that's the only other thing that can come to mine I'm assuming cooling isn't an option
PS if it's only been a few months can you take advantage of the warranty one of my go to the rules is always buy a video card that has a lifetime warranty they tend to cost a little more but the extra 20 or $30 in the long run comes in handy sometimes
thats my .02
MCtek
400+
Re: Tek Streams!
Post by MCtek »
thank you for the info LH, i did check to see, but i didn't see anything blow on the MB and the video card is encased so i really couldn't see the inside of it, but it does appear to be the video card as i switched card a Radeon R7 260x, gave it a test and it seems to be running fine now, the only real thing is it doesn't seem to like OpenGL too much and gives me this weird camera glitch were if i pull far away the clothing on models appears to be disappearing, i'm sure it's just how the card is build rather than an actual problem. It'll have to do for now until i can get a stronger, new video card.
Daniel~
monkeyjr
Re: Tek Streams!
Post by monkeyjr »
Glad to hear it's better than it was, Tek! Haha
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Starting the stream in a few mins, hopefully i don't have problems with the stream, thou if it starts getting glitch happy i'll have to shut it down :P *fingers cross* hope to see you all there!
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Daniel~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
MCtek
400+
Re: Tek Streams!
Post by MCtek »
Hey gang,
Tek~
picarto.tv/Tek
